help!
marty f
WATERTOWN,MN
i have been looking for 48/40 advant edge helix but apparently they must of never existed because i am getting no feedback of where to get one and or they are so precious no one will give one up can someone lead me in the right direction????? :o|
Helix
Contact Micro Belmont Engineering in Grand Rapids, Michigan. 616-534-9681 ask for Gary. He has a ton of helixes and they make custom parts also. They are great people. Good luck. Pat
Talk to Ulmer Racing, he is a sponsor on this cite, also check the classifieds you might find a good used one. You could always drop a PM to Turk, he probably has a few lying around his shop.
Why don't you pick up the phone & call them. It's not going to snow this weekend, relax. Info below.
Advant-edge is still in business, I talked to the owner several months ago when I bought my helix, they are NOT selling to the public anymore.
Simon's CPR Supertuner helix's used to be made by Advant-edge as well, not sure if that is still the case or not. http://www.simonscpr.com/
ULMER INFO:
This post is to let all you TY users know the easiest and most convenient time to
call us here at Ulmer Racing.
Monday thru Friday
3:00 PM to 7:00 PM
Saturday
9:00 AM to 3:00 PM
Sunday
CLOSED
**We are located in the central standard time zone so check your time zone compared to ours when calling!**
If you call and someone does not answer, please leave a message with your name, phone number, and information you are looking for and we will gladly return your call within the next day in most cases.
If you call and the answering machine does not pick up we are on one of the other lines and can't switch lines. Please try back again later.
Phone: 605-387-2833
Fax: 605-387-2883
Email: Srxspec@Gwtc.net
Like SRXer said, give Ulmer a call and check with them or contact Simons CPR. You'll just have to get on the horn and check around. The advant edge helixs seem to be pretty elusive.
you can get them from your dealer or i think simmons racing. i know he quit selling direct to the public 2 years ago.
he quit selling to public just when i was ready to get my sxr clutch kit because i was going to buy it from him.
You need to keep looking for the advant edge helix. Careful on the angle….the advant edge helix allows the stock buttons to shift in both directions MUCH easier.
Try this test….grab the belt (with the stock helix) and you can almost lift the front of the sled off the floor by pulling on the belt.
With the advant edge helix….the secondary opens like it was on bearings…..by pulling on the belt. (at least up until the mid 2000's year)
Don’t worry about his roller or for that matter – any other roller….there is very little if any improvement over using the advant edge helix.
We got to play with a TEAM secondary last winter a bit – that would be my choice over a flat ramp style. The thing had some amazing feed back and very sensitive to the shift balance. Lots on ebay – the older 8 bolt is just fine.
;)! Oh - we have a full range of his helixes - even a bunch of reverse angles - not for sale.
