I got some different limiter straps for my Expert. The stockers didn't hold up.
I'm not sure if I have the correct "standard" length straps.
What I need to know are the measurements from bottom shaft to top shaft fully extended. I would like to know these measurements for both DTR and without, as I have the DTR, but I'm not sure if I am going to install it just yet.
If any of you have pics of the upper rear shaft that the shock mounts to also would be great so I can see how all the little bushings and spacers are on there both with and without the DTR installed.
Any help would be great. I took this apart awhile ago and couldn't get back to it until now. I know I should have snapped off a few pics of it, but I didn't.
Thanks,
1CS
Thanks,
1CS
Help
If you have the stock limiter straps is there any reason you cant compare them to the new ones you have? Wouldn't someone elses limiter strap length depend on how much ski lift/transfer they preferred? I know that I run mine shorter than the stock setting. Finally, on the spacer detail, if you pm me your e-mail address I will send you a detail of the skid in pdf format. I tried to attach it to this site but it wouldn't take it.
Madmatt
Madmatt
Madmatt said:If you have the stock limiter straps is there any reason you cant compare them to the new ones you have? Wouldn't someone elses limiter strap length depend on how much ski lift/transfer they preferred? I know that I run mine shorter than the stock setting. Finally, on the spacer detail, if you pm me your e-mail address I will send you a detail of the skid in pdf format. I tried to attach it to this site but it wouldn't take it.
Madmatt
They are toast. I had to trim them and run it REALLY REALLY tight just so I could get the sled home rather than run without any. Boy, talk about ski pressure. whew...
I did think of that, but the one I do have is just wasted.
I have the actuall print I got from AD when I baught the skid that has the diagram of parts on it, but there one or two little parts that I'm just not sure how they go.
I'll pm ya my email....
Thanks,
-Vince
ExpertXViper
If my Viper was home Id glady help ya out, but its a good 3hrs away. Try calling Aaron at Excell Motorsports, Im sure he'll be able to help ya out.
Vince post on the 4 stroke side. the expert guy is over there alot. Maxdlx
maxdlx said:Vince post on the 4 stroke side. the expert guy is over there alot. Maxdlx
Did that first...
