Tony Need Help Setting up a 79 SRX 4 Grass
Mrholshot
Toledo
Tony, I heard you were the man with setting SRX's up. I have a 79 that I picked up the other day. I am planning on taking it to the local grass drags to do some vintage racing and hopefully whoop up on some bigger sleds. I was thinking about notching my weights (how much and where at?), gearing it down 2 teeth on the top sprocket for 500ft, jetting down the mains 3 sizes or so, and putting about 48 1.075 trail studs in the track. There are no rules so anything goes. What RPM's should I shoot for? Thanks
Comet Clutch I believe
I believe it has a Comet clutch on it. It has a real thin cover on it.
MRHOLSHOT. HERE HAVE AT IT.
17-31 GEARING.
COMET 102 c
N-1 WEIGHTS ( need to notch )
NO LESS THAN A 5500 ENGAGEMENT
GET THIS SPRING 207758. COMET PURPLE WITH 1 SHIM. RUN THIS SLED AT 9000 IF YA STILL HAVE STOCK EXHAUST. ALL THIS STUFF IS STILL AVAILABLE FROM COMET. 3:16 (yammie tony)
