Track tight after suspension mod
Fro
Howell, Mi
Put Vipers on the rear. Also a new 1" Hacksaw. Track seems too tight at the curve now even if it's adjusted way loose. I added 5.38's to help wear. Thinking of a small wheel kit now too. The track does slightly rub the protectors, doubt that would cause it. Any thoughts. Thanks, Fro
the curve? u mean the front of the rail? the way to check track tention is at the middle of the rail. i usualy push down with a moderate force and see if i can get between 2-3 fingers stacked ontop of each other and thats usually good. if u cant atleast 2 fingers between the hyfax and the track its too tight. also did u lossen the shaft that goes threw the rear wheels. cause u can loosen the tensioners up all u want but the wheels wont move unless the rear wheels are lose.
What I'm saying is that the track is tighter at the curve in the rails than it was before the mod/track install. whether the track is at the correct adjustment or if it is really loose. May be me, just seems tighter. Would the limiter straps have any effect on this. I did get the Viper ones...like 2'' longer.
yea they puts that part of the track out farther. but u want that shock extened so that it can travel full stroke. that is if ur riding any kind of whoped trail if u ride compleatly flat all of the time u could suck it up for more ski pressure.
Guess what? When you have the sled on a stand the track is tight on the front of the rails...when it's on the ground with someone on it---it's not. I really can be a douche bag when left unsupervised. Sorry for wasting the bandwidth.
