Oil injection on a 1991 exciter 2
LukeWilson
Ottawa, Ontario
So when i got the sled the carbs were out and the oil injection lines were disconnected. So i have determined that the oil lines do not go to the fuel pump, the bottom of the intake boots or the carbs. So where do they go?
Thanks,
Luke
The oil injection lines on a 570 Exciter go to a plastic double T in the fuel line on the incoming side of the fuel pump. The oil is injected into the fuel, mixed while going through the pump and sent to the carbs along with the fuel. It is not injected into the carbs or intake manifold.
Good Luck, Phil (opsled)
Thank you soo much, i went and look at the sled and it appears to have this
tee, but it is capped off. I know that my oil pump works so who knows what was going on.
