speedo cable problem
yamaha
Grand Rapids, MI
Website
www.silverlakeforum.com
i recently purchased a used speedo cable and installed it. Now, when i start my sled the high beam light comes on and the speedo still will not work. Does anyone know what this could be? I know i installed it right, but is it the wrong type of cable? any help would be appreciated.
u check the key that goes into the drive shaft? if ur speedo stoped working its usualy that cause ur bearing is goin and the key sheared off. take the hub off under the secondary clutch and check it and if is sheard id replace the bearing too. a 40 buck bearing is cheeper then a tunnel
