02 700 mm jetting
Newfoundlander
Corner Brook NL Canada
I have a 02 mountain max that i am going to install bender triple pipes on. The jets i have picked up are 150 mains and 50 pilots i was wondering if they were good for 0 - 2000ft and a temp of -25 or would it be on the lean side the only mod i have done is reed spacers. I was also wondering what clutch setting you may be running.
I put a set of Benders on a 98 700 MM (same engine) last year, what a difference! I started with 152.5 mains and 55 pilots to be on the safe side. We had a fairly cold winter so I left them alone and it ran fine. I have a Vari-flow installed and went 3 clicks to the lean side in April. Clutch set up I have now is 8-ca weights with no rivets, O-P-O primary spring, stock secondary spring and helix @ 70 degree wrap. I have a multi-angle hellix from Bender that I'm going to try, as well as some 89-L weights. All I need is some snow.
