hunter78
I want to swap out an electric starter from a 2000 MM 700 to an 2002 MM 700. It looks as though it would just bolt right in. My concern is with the electrical. Could anyone help??
Most of the older Mm and sxrs where all wired the same from the factory. it should be a direct swap. You will need to remove the smoothing condensor from the none Estart sled, and put it back on the one you are robbing the E start from. Maxdlx
