I've been doing some research on here about doing the Viper suspension mod on my 98' SRX and noticed someone had said the SRX rails have more of a "turn up" than the Viper rails. I have a complete Viper skid and was wondering if I should swap the SRX rails onto the Viper skid or does it not matter?
it does not matter. there were a few different rail ends, none of them any better than the other as far as i can see. you may want to read the article below for some information on making the suspension work better and longer for you.
i would just install the viper skid complete after going through it.
BETHEVIPER said:it does not matter. there were a few different rail ends, none of them any better than the other as far as i can see. you may want to read the article below for some information on making the suspension work better and longer for you.
Excellent Thankyou!!
When I picked up the Viper skid I gave gave it a bit of a check over and it seemed to be in great shape, later that evening I printed out the article you wrote and headed out to the garage. I was shocked to discover that every bushing was indeed very worn and the entire skid was pretty sloppy!!! I'm now in the process of giving the BETHEVIPER fix!! Thankyou, for the excellent article and for sharing your wisdom!!!
