Concept Carbon
just got some aftermkt 157.5 jets installed them and they are al little bit wider in size the the stock yammy ones but are the same height is this ok?
here is a pic
here is a pic
SX700triple
2upperDeluxe
It should be fine if they dont come into contact with anything in the carb.
JeepTherapy
I like it, numbers big enough that even I can read them! Is that what your going to run with the SRX pipes?
Concept Carbon
im going to start with that
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
As long as they give you the same flow, it's ok.
Bruce
Bruce
