looking to put a rear heat exchanger from a srx in the the viper tunnel and if it fits with out any problems,,,thanks
viper48
If you are talking about the HUGE heat exchanger that is a yes. I put an SRX rear heat exchanger in my 2002 viper.....no problemo! Mine came with a paper template that I didn't use. You reuse the same hoses, all you need is some rivets......now that I think about it.......the rivets came with my heat exchanger.
the only difference is the hole for bleeding the coolent is in a different place, just need to make a small hole over the screw
Yes it will work. I would'nt mess with the small one. I bought a new one from Pioneer for $79.95 earlier this year. G.B.
