marty f
what size rod spacers do i need when i am long traveling my srx(top-bottom)
x2ryder
Pioneer says 10mm. You can buy them from Yamaha.
marty f
rods
is that with the stock viper rods
x2ryder
Sorry that is on a SRX.
Rambunctious
there is a yamaha suspension setup discription somewhere on the board. calls for the proper gaps on both sides ( 7-10mm????)
you may need shallower spacers on one side vs. the other to get those proper gaps. hang over the sled with your full weight and measure the existing gaps, then with knowing the proper gap, you can buy or make the proper size spacers.
Ramb
Ramb
