Viper Spindles/Arms on a MM
mecheng
I have a 1999 MM700 I would like to raise the front without spending a ton of cash.
Anyone know what Viper arms and spindles fit my sled and what amount of lift I should see? Is there any other parts I need besides the spindles and trailing arms.
Thanks for the help...
Owen
Any Viper arms and spindles should fit. You will also need the steering arms that go on top of the spindle. If memory serves me corectly I think the spindles are a little over an inch taller.
I gained about 1.25" on my srx. Ans He is right, you also need the steering arms on top of the spindles.
So it is not necessary to have the viper shocks as well? Would it add more lift to have the shocks also?
if you add the shocks you would have to widen the front end. If you don't you have to preload the shocks to get them on, and it rides roof like a lumber wagon. Longer travel shocks dont raise the front end. Maxdlx
