installing saddless skis on SRX
saskattakman
Sask Canada
what parts will i need to install the new 05-07 mountain models saddless skis on my 98 srx....i like the look and width of these skis....just dont know what i need to put them on...thanks for the info
ya im still game with these skis.....anybody know any part numbers of longer bolts and spacers from yammy???.....also is my sled gonna sit lower compared to the stockers??? im looking at something wider then stock to keep my front end higher in the deep powder
got all the part numbers figured just wondering yammy web site listed a bushing number 3 will i need this to install these skis??? got the longer bolt, both spacers, spacers for carbide and skis.....also what carbide should i use??? doolys??and what length carbide???i have 1.5 136 track and do 50 50 trail powder riding.....will my sled sit lower with these skis???
If you have the steel or cast aluminum saddle skis, it will sit roughly 1" lower in the front.
I'm pretty sure my flatlanders came with #3 installed. So #5 x8 and #14 x4.
ok thanks so what should i do to get my sled 1" higher with the new skis??? should i flip the brackets side to side or get shock extensions?? also what carbides will work best for me??
i have heard through port yamaha that installing saddless skis on proaction front ends will cause the ski to hit the trailing arm under flexing conditions is this true can anybody relate to this....could i use viper spindles and make a spacer or use viper arms what works bestthe yammy skis are about 200bucks cheaper then other aftermarkets so im weighing my options
I was warned about this but haven't had it happen yet. The biggest problem would arise going slow over ridges/snowbanks and trying to turn. The rear of the ski could 'possibly' come in contact with the trailing arm and freeze the steering momentarily. Weigh the problem for yourself.
You could do the viper trailing arms or a newer Vmax for that matter, I thought about a spacer but there a strength issues to consider.
srx maine i read those links....still thinking about doing it just heard from 2 yammy dealers that the ski might/will hit the trailing arm as the ski is now 1 inch closer to the trailing arm....wondering if anybody else has this problem
Ive had the new mountain skis on my 01 mm700 for two seasons. Riding aggresively I have never once had a problem with the rear of the ski hitting the trailing arm.
Tom
how would the sadlless skis compare to the c&a XT model??? they are roughly the same price for new....just wieghing my options
