unchained
Picked up a really straight and solid 1980 Exciter. It starts after a half pull and idles great and has great compression, but bogs so bad that it wont pull itself across the grass? On the stand it revs to about 5,500-6,000 slowly and will burry the speedo, but on the ground it has nothing? It doesnt miss but sort of sounds like it drops down to 1 cylinder off idle. The clutch side plug looks fine but the mag side is usually a little damp. I did find the bumper bolt to the belly pan where the wiring grounds was loose so that took care of my dim lights and also I found a fraid yellow wire under the seat but nothing yet has resolved the bog and lack of power. I know both cylinders fire from feeling the y pipe but Im guessing without EGT's that the mag side is not as hot. I have changed plugs several times and no diff. Thanks!
Ryan
Ryan
i would check the condition of the reeds and clean the carb and put new spark plug end caps on
YAMMIEGOD3:16
GOOD START RIGHT THERE. 3:16 (yammie tony)
unchained
I already pulled the reed cages and the reeds are perfect. The carb is spotless and I did cut off a 1/4" off the coil wire and re-threaded them back into the original caps but I could try new caps to I guess.
YAMMIEGOD3:16
YOU GO THROUGH CLUTCHES. 3:16 (yammie tony)
Hey
Had a 79 Ex. and I know what your problem is.
You choke plungers are like GUMMY WORMS!!!
Clean them out.
Tom
Clean them out.
Tom
unchained
Yeah, I already went through the clutches and although the primary is getting pretty sloppy (6,000+ km), it is in tact and was nothing more than dusty--but had good free movement and the spring was not broke. TONY--ONE THING I DID NOTICE THOUGH WAS THAT THE PRIMARY SHEAVES GET REALLY WARM TO HOT DURING THE 1-3 MIN I RUN IT ON THE STAND. I THOUGHT I WOULD HOPEFULLY FIND A BROKEN PRIMARY SPRING BUT NO LUCK???
Tom---The very first thing I did was clean the carb and make sure the choke wasnt sticking but I am goig to disconnect the plunger from the cable and make darn sure that it is fully seated in the carb though...
YAMMIEGOD3:16
PROBLEY STILL HAVE SOMETHING GOING ON WITH THAT PRIMARY ESPECIALLY IF ITS THE YAMAHA PRIMARY. THERE WERE VERY HIGH MAINTENCE. PROBLEY BUSHING WORE OUT CAUSEING SLIGHT HANG UP. THATS WHY CLUTCH IS GETTING HOT. I HAVE SEEN THEM BAD ENOUGH WHERE SPIDER MOVES OR SHAKES. 3:16 (yammie tony)
unchained
I dont dissagree but even with the belt off it doesnt rev strong and has a bog when free revving???YAMMIEGOD3:16 said:PROBLEY STILL HAVE SOMETHING GOING ON WITH THAT PRIMARY ESPECIALLY IF ITS THE YAMAHA PRIMARY. THERE WERE VERY HIGH MAINTENCE. PROBLEY BUSHING WORE OUT CAUSEING SLIGHT HANG UP. THATS WHY CLUTCH IS GETTING HOT. I HAVE SEEN THEM BAD ENOUGH WHERE SPIDER MOVES OR SHAKES. 3:16 (yammie tony)
unchained
BTW, what is the peak rpm for these sleds again? I use to know all of the old Yami iron specs back in the day!!
