Coles_55 New member Joined Dec 5, 2005 Messages 1,227 Age 39 Location Eagle, WI Oct 23, 2007 #1 What size bolt is this part number 97017-06025-00??? Its the bolt that holds the reeds onto the block....
daman New member Joined May 2, 2003 Messages 10,569 Age 54 Location Bad Axe,Michigan Oct 23, 2007 #2 what ya looking for head size,thread size? whole bolt?
Coles_55 New member Joined Dec 5, 2005 Messages 1,227 Age 39 Location Eagle, WI Oct 23, 2007 #3 I lost one of mine some how, and I need a replacement. But I work for Fastenal so I can get it cheap. And Yamaha wants you to buy 12 of them..when I only need 1....I know its metric, so its M_ x __....
daman New member Joined May 2, 2003 Messages 10,569 Age 54 Location Bad Axe,Michigan Oct 23, 2007 #4 I see.... really you can't get just one? i do all the time from my dealer..
Coles_55 New member Joined Dec 5, 2005 Messages 1,227 Age 39 Location Eagle, WI Oct 23, 2007 #5 Ya I just tried and he said I have to buy 12 of them for 10 bucks, when I can just get them here for a lot cheaper.
daman New member Joined May 2, 2003 Messages 10,569 Age 54 Location Bad Axe,Michigan Oct 23, 2007 #6 sled looks good from your avy, get some pics up..
Coles_55 New member Joined Dec 5, 2005 Messages 1,227 Age 39 Location Eagle, WI Oct 23, 2007 #7 They are up in the photo section...
yamaholic22 Active member Joined Oct 23, 2003 Messages 5,276 Location Iowa Oct 23, 2007 #8 It is a 12mm head and probably an 8mm bolt, not 100% sure on the 8mm though.
Coles_55 New member Joined Dec 5, 2005 Messages 1,227 Age 39 Location Eagle, WI Oct 23, 2007 #9 Damn, I guess I will try and see if I can get Port Yamaha to just sell me one if I buy a helmet from them...
D dmsrx700 New member Joined Oct 23, 2007 Messages 13 Age 63 Location Indianapolis Oct 23, 2007 #10 6mm bolt, 25mm long, 1.0 thread pitch.
M-Max New member Joined Nov 4, 2006 Messages 280 Age 57 Location Whitehorse Yukon Oct 24, 2007 #11 Take one to work. Find the right nut for it, Then you will what bolt to get.
W WATCHMAKER Member Joined Mar 23, 2005 Messages 118 Location Northern, WI Oct 24, 2007 #12 dmsrx700 said: 6mm bolt, 25mm long, 1.0 thread pitch. Click to expand... Correct... look at the part number...often the size is buried in the part number.
Coles_55 New member Joined Dec 5, 2005 Messages 1,227 Age 39 Location Eagle, WI Oct 24, 2007 #13 Thanks, going to grab one right now!
