katkiller
put the 10 ek plugs in looking for more.
the sled is stock otherwise.
would that be a 3 degree timing key?
you can get the fuel accelerator from hauck
If your racing 1000' or less get the 12 degree timing key but u gotta run premium & it will cost you top end. Otherwise run the 2 degree key & it will help you right thru to top end on regular pump fuel with less low & mid.
katkiller
apex
how about air box mods?
jr_amsoil
a turbo would be. it seems like a lot of money which it is. but for that kinda power its not that bad.
Srxspec
Your #1 performance shop!
Air box mod, Powercommander, and Ignition Module will give you more adjustability for fuel and timing control than anything else currently on the market.
