Questions Before First Startup
matnaw
new york
Just finished putting my sled back together and have a few questions before I fire it up. I cleaned and adjusted the carbs and was wondering where the fuel screws should be adjusted. Its a stock 98 srx with 1.146.3 2. 146.3 3. 148.8 main jets. Stock reccomendation is 1 1/8, is this a good place to start? I also just put on a bender silencer, do i need to rejet? I replaced the fuel and oil lines and bleed the oil pump, should i run pre- mix?
Try this
Here ya go
1998 Yamaha Sleds:
Models 98 SRX 700
Engine (cyl) 696 (3)
Carburetor
Type Mikuni TM33x 3
Main Jet 1/2 - 146.3, 3-148.8
Clip Position 3
Pilot Jet 42.5
Float Height (mm) 13.3 +/- 2
Fuel Screws 1 1/8
Pilot Air Jet 1
Idle RPM 1800 +/- 100
Drive
Engagement RPM 3800
Shift RPM 8500
Belt Type 8DN
Sheave Ctr to Ctr 268.5 mm
Sheave Offset 15 mm
Clutch Weights (rivets) 8dn-00 w/13.3 & 17.2
Roller Type 15.6mm
Primary Spring G-G-G
Secondary Spring Red
Secondary Setting 60 deg
Helix Angle 47 deg
Gearing 23/37
Chain 70L
Run a small amount, 1/2 tank fuel half qrt oil or just make oil cable rich, but not too rich...you do not want to create a lean out condition...After my rebuilt I just richened up the oil cable and made the fuel screw rich and ran 1/2 tank/oil premix... watch temp on engine closely and then when I went through my 1/2 tank I reset my oil cable to stock and fuel screw...But my sled was all stock, no after market can...hope this helps
theblues said:
Here ya go
1998 Yamaha Sleds:
Models 98 SRX 700
Carburetor
Type Mikuni TM33x 3
Clip Position 3
Pilot Jet 42.5
Fuel Screws 1 1/8
Pilot Air Jet 1
Drive
Engagement RPM 3800
Shift RPM 8500
Belt Type 8DN
Sheave Offset 15 mm
Roller Type 15.6mm
Helix Angle 47 deg
Gearing 23/37
Chain 70L
Is this the same as the 99? If so I'll be printing this out and getting everything perfect when I go through it.
Open up your fuel screws to 1 1/4 turns or so and it will run better in the bottom end.
