vintage srx
Pulled out my brothers sled from storage,It only wants to run on 2 cyls.Center pipe is cool after running her,going to check everything out.
mrviper700
VIP Lifetime Member
clean the carbs
TopGunnSrx
Check the carbs. I bet one is plugged up.
vintage srx
Going threw her tonight.
Turk
TY TECH ADVISER
- May 2, 2003
Carbs or change the plug. I bet it,s the plug.
vintage srx
We tried new plugs but center cyl still not firing.
Skidooslayer687
are you getting spark in the center cylinder?? just thought i'd ask the obvious lol
1) check for spark with a new plug,
2)check for fuel, is the plug wet? if not, try spraying a bit of gas in the plug hole, if it runs on that cylinder but quits after the fuel is burnt, then pull and clean the carb
3)if you have spark and fuel but still won't run, do a compression check
4) if the compression is good and you have good spark and fuel getting to the cylinder in question but still won't run, then I would check to see if you had a broken piston skirt
mrviper700
VIP Lifetime Member
I thought the "key" word in the first post was is "was just taken out of storage", so I guessed it would be the carbs are dirty and the pilot jets plugged up??????? just my guess as to the description provided.
I'd have to agree!!! Dirty carb would be my bet!mrviper700 said:I thought the "key" word in the first post was is "was just taken out of storage", so I guessed it would be the carbs are dirty and the pilot jets plugged up??????? just my guess as to the description provided.
vintage srx
Pulled out carb rack took carbs apart seems to be clean.Compression is good,also checked resistance on plug boots one has 4.965 komhs,9 on the other and i cant get a reading on the last one.
vintage srx
Going to tell my brother to purchase some new caps this week.
vintage srx
Forgot to mention that after foging and stayblizer added i drained the bowls.
TopGunnSrx
I ran my srx out of fuel and i had a hard time getting it to run again this fall. I ended up just putting gas straight into the cylinder a few times to get it to run enough to get some fuel flowing.
mulderdad
Its a pilot plugged.
I just went through this on my ol srx.
My center cyl pilot was totally blocked. After a good cleaning, runs mint again.
Rick.
Rick.
yamyrider
CARBS, CARBS, CARBS and maybe its tha carbs......oh and I would clean tha carbs.
The second thing would be to clean the carbs.....dont just look and say they are clean.
Take another look
Throw the plugs in the caps and ground to engine & see if all have spark, if so than as everyone says, go through your carbs...really not that intimidating, blow dry them out, adjust your floats, put them back on & your good to go...let us know how ya did...
vintage srx
Im not intimadated the carbs are spotless inside.Replaced sparckplug boots all is good now.Thanks for the input.
