going to bigger track
deeppowder
BC
I'm going to a 151 track this year. While I have the skid out, I plan to replace the jackshaft and driveshaft bearings. Is there anything else I should be inspecting/replacing while the skid is out. Hopefully it won't be coming out again for a long time.
Anti-ratchet drivers are a must. Check for cracks. Do a search on suspension rebuilds. There is a boat load of good info on what to do while it is apart. I like the Mtn. Preformance transfer kit. If you are not going to add pipes or anything else for more hp, think about gearing it down a little so you can spin the track when nec.
Bought the relocation kit from Mountain Performance, also have a new driveshaft complete with 8" anti-ratchet drivers. Put pipes on last year, and now need more track.
