shotym2
Bought a bare P85 and need a baseline setup (close to stock) on a 600 twin. I was going to start with similar weight and spring tension but I look at the clutch kit suppliers and the yam base weights are always way lower. Was going to use the comet setup as a reference but when I check the engagement rpm in their handy table it shows 2500 which is way to low.
My current setup is 8ab, 13.9,13.9(48.2 total),WSW and was thinking polaris 10 or 10M weights and Erlandson black or green spring. The clutch is a wide roller,wide bushing off of a newer 800 twin so hopefully the roller bushings will last more than 200km.
Thanks in advance.
Thanks in advance.
