Viper_Jim
I've got a chance to buy some mountain skis from both a Nytro and Apex.....will either of these fit on my 04 Viper????
thanks!
thanks!
skidooboy
yes they will, you will need the bolts (2), spindle bushings (2) and spindle bushing collars (4) from an 06 mountain viper, your stock rubber ski bumper are the same as the mountain viper. ski
xsivhp
hmm I thought apex skis and viper skis were the same? what year did they change them?
xs
xs
grapeape
Mtn skis are different than the 121 and 136 sleds by a few inches
xsivhp
Are the mounts different, too?
Viper_Jim
I know that the skis are much wider....I'm interested if they will bolt on or itf it is at least posible in some way. I'm trying to get skis from an 07 Apex or 08 nytro to fit my 4 Viper
Powder Trax
I have the mountain Apex skis on my 2004 MNT Viper I just bought recently. The previous owner just had to shim it. If you go one way it gives you a wider stance, and if you place the shims the opposite way its narrower. Kind of Offset skis like on the Polaris
Here is a front picture. Hope this helps.
They will bolt on, but you'll need parts like skidooboy suggested. I believe the stock Viper ski has the stamped aluminum saddle?
skidooboy
apex and later viper shortys may have the same saddless ski. the older vipers had a aluminum saddle mount. he is talking about a mountain apex and mountain nytro. there are no mounts, (saddless). you just need the right hardware configuration. bolts, bushings, collars, rubbers.
the new mountain ski's are saddless, all you need is what i stated above. i just sold a set to a member here in alaska, and sent him the parts to make them fit too. direct bolt on. 2 bolts, 2 bushings 4 collars. you will reuse your nuts and rubber bumpers from your stockers.
go to the micro fische for the 06 mountain viper, look up the ski. order the bolts (2), the long bushing (2) that goes into the hole in the bottom of the spindle, and the collars (4) that slide over that spindle bushing. and new nuts (2) if you so choose. ski
cos in alaska
Viper_Jim
Thanks for all your help guys....my skis on my 04 are saddleless so according to the pics I souldn't have a problem, I actually went town to the local dealership yesterday to check out the skis on an Apex Mountain...
