Help
marty f
WATERTOWN,MN
Just Finished Installing 02 Viper Shocks On My Srx I Put The Limiters All The Way Out Installed The Viper Transfer Rods And Put It Back In...now The Problem Is Something Is Wrong It Is So Stiff I Cannot Get The Suspension To Budge When I Even Hop On It (i Am 210 Lbs) What Is Going On I Looked At The Transfer Rods And They Are Pushed Down All The Way To The Top Washer Of The Rod
Marty when I did mine I just put longer limiter straps and that was it....bolt it right back and worked.....Maybe you didn't got the suspention mounted right ( i don't know if that is possible) but maybe how about the shocks are they good.....Anyways I can try to help you if you want at home, maybe the two of us can figure it out better....Let's try to ride this year....Nick (from Mound)
help!
I DID NOT KNOW THAT YOU MOUNT THE TRANSFER RODS IN THE BACK HOLE SO I NEED TO DO THAT I HOPE THATS THE PROBLEM :letitsnow
How are you doing marty...? Got it..? On the front ones I just attach them to the bulhead....I had some spacers and washers to make them work
Nick
