99 Vmax 700 coolant tap
coreysask
Balgonie
Website
corey.cabler.com
Hi,
I have a 99 vmax 700 that was a coolant leak at the tap mounted on the airbox.
Is there any value to it on the 700?
What is I removed it and put in a straight through connector or plugged off the ends and not run coolant through the carbs or replace the stupidly expensive thing? (anyone have a used one they wish to part with?)
Corey
Mine was doing the same thing. I took it apart and cleaned it and re fitted the snap cap lid and it seems to be ok now. I was thinking of just using any old valve from a harware store if it didn't work
