marty f
what size would be the best for my idlers on my srx i heard pol 5.35, is larger any better or worse and i need to know how to make them fit as for as the bearings I.D
			YamaChris
Check the tech section on the TY homepage under reducing hyfax wear.  There is a write-up on this for using the Pol wheels.  That seems to be the easiest change for hyfax wear.
			To make them fit all you do is simply pop out your stock yamaha plastic bushings and pop them in the polaris 5.350 wheels and they bolt right on. When you look at the polaris wheels in the aftermarket books they will list differnt i.d. sizes, but they all use the same bearing, the i.d. sizes they list are the plastic bushings youll not be using anyways, so it doesnt matter as long as they are 5.350" in diamter(wheels)
