Do I need to switch rollers?
Fro
Howell, Mi
Going to 8dn20's soon & read some info on roller changes. Not sure what to do. Thanks, Fro.
99 SRX700 has 15.00mm rollers
00-02 SRX700 has 15.6mm rollers
Im not sure if you have to change the rollers for the clutch set-up your going with but I would assume YES.
using a smaller roller will lower your engagement and shift speed slightly,going from a 15.6 to a 14.5mm is a fairly big jump but from a 15.6 to a 15mm wont be giant, youll need a little less weight(rivets), the good thing is the weight will act heavier with the slightly smaller roller, more aggressive.
