egt probes
gates26
ontario
How do you determine where to put the EGT probes on the pipes?
Bender big bore pipes.
it goes from the piston skirt, meaning the front edge of the piston skirt out usually 7 inchs, thats where the probe will go, as far as the angle or spot thats up to you, check with your probe manufacture for your dimension.
