2001SRX=Fast
Okay i got 2 questions
1. I just put in new cylinders and piston/rings whats that break in procedure?
2. what stock gearing for 01 srx?
23-38 for the gear
Run yamalube, a little pre mix in the tank also(don't get carried away)2001SRX=Fast said:1. I just put in new cylinders and piston/rings whats that break in procedure?
vary the throttle(RPM's), run for a hundred or two miles then ride as normal
after break in use a fully synthetic oil,Amsoil,Klots,etc..
