i am installing a 1/14 track on my 2000 sxr sled . i am also replacing the drivers with the 8tooth . does any body know what gears to run to get me back to stock . thanks
24/38 will get your gearing exactly back to what is was with 9 tooth drivers.
I have a 24 tooth
Good news is that you can still use your stock chain with the 24/38 and those gears will take some rolling friction out of the top sprocket since the 24 is bigger. Your chain wont have to bend around the top sprocket as much
