I am getting 4 new OEM 8DN belts.I will scrub them good first in hot water and soap and then you put on sled and put in at least 50 miles of no pinning or WOT.You vary the speed up and down,but don't go past 50 mph.Is this about right.Can belts be broken in properly even if I have a HC set-up in my clutch.I ask this because the HC's will clamp the belt more and would this be good for break-in.Could break-in the belts on my 600 SXR first or does it matter really.I want to do it right so the belts will last longer.
