Headlight Fuse Blowing
RJ82much
western MA
Hi all,
Anyone having trouble with headlight fuse blowing? (2002 VIPER/srx)
I've measured the amps, checked all wiring from fuse to lights, thru switches, etc. I've replaced the bulbs & upped the fuse size from 20 amp to 30 amp. No change, when I switch from low-beam to high beam, the fuse blows. The only way to prevent it is to unplug a headlight (doesn't matter which one).
This only started occuring the last 2+ years. High-priced Voltage Regulator???
Bob
