Are 14.5 MM rollers between the 2 and 4 strokes the same?
Are the 4 stoke rollers wider beacuse the weights are wider?
If so, I need a set for a 4 stroke
They take the same roller & are the same from 97 & up(inside pin diameter) The pre 97,s rollers are the same outside diameter but the bushing is smaller & they take a larger pin 8mm vs 9 mm.
I have 9mm I.D. rollers that I want to put on my MTN Apex.
will they work?
will they work?
