srx motor in viper chassis
srxdoug
ohio
does anyone know if a srx motor will fit in viper chassis with any minor adjustments?
Concept Carbon is also in the process of doing this. However he is just fitting the SRX pipes on to the viper motor I beleive. A few things are involved such as cutting the bellypan above the mag side shock tower to clear the exhaust pipe. Is it worth it??? That's the question you need to ask yourself. I personally would do it in a heart beat as I love the looks of the viper (not that I don't love the looks of the SRX hehe) and getting the 140 hp under that hood with great gas mileage and reliability for a set of triple pipes makes it a no brainer for me, however some fabrication is invovled (at least for using the viper motor) and it helps to swap out some core motor components (cylinder heads, CDI's etc) This is what I gathered from reading the posts on what other people have done going this route. Do a search for SRX motor in Viper and you should come up with some good results.
Good luck if you decide to do this.
memorys, like the corners of my mind, misty water colored memories, like the way we were
