schmidtty
what is causing this problem on 1997 sx 700 vmax new w arm and shock
woolyviper
track is billowing - check the tightness of the track.
terret725
what shock center or rear? if bottom center is rubbing means u blew out the bolts that hold the mount. rear if u have an ohlin or anu shock with a resivor its cause u dont have 7.5 inch wheels if its a stock shock might be tention or ur upper wheels rubber has delamitated and riped off. befor u start gettin all worried every shock gets rubber a little no matter what skid. the thing that matters is if its enough to rub threw or not. oh another thing ive noticed wich is big with polaris is if the hifax rubs threw to the point of ruining the rails it allso ruins the bottom of the center shock.
Mine was rubbing too but it turned out to be the shrader valve on the end of the rear shock. Some one installed the shock up side down. I didnt even have to take the shock out to flip it over. Just unbolt the one end and twist it.
