shavedheadedyamaha
whats good compression on a 98 700 srx triple i pull 119-120 on all 3... it runs great and sounds great.... any help would be great
Is this motor stock? by the looks of your sig. it's not..
shavedheadedyamaha
no just shaved piped and jetted.... the sig is all there i dont think i forgot anything
Someone else can jump in but i think with shaved heads your on the low side.
did you test it @ operating temp throttle open with 5-6 good hard pulls?
shavedheadedyamaha
not at temp or the trottle open just as it sat...
There's where ya went wrong, re do it @ op temp and WOT, hard pulls,
should see better numbers
shavedheadedyamaha
what should i be looking for
Not shure with your shaved heads,IIRC my '01 has like 130-140ish in that
area.
area.
shavedheadedyamaha
man i love this site .... lol lol if i have a q someone has some anwsers.... i feal like this site is live tech support for yammies ( the elite might i add ) lol thanks well ill do some check later today and let you know..... is the op temp very important because the pipes are taken off for paint and i'm waiting for gaskets
Lol.....
test it like i explained it's the proper way.
well maybe your guage is wrong .. depends if the engine is ported but with shaved heads its seem low ...
saskattakman
ya does seem low i am runnin a stock 700 and its pumping 120 right across with 13,000 kms.....with the shaved heads should see a bit more
Rememeber, not all compression guages will read the same!! Especially those universal ones that dont use the long 14mm thread adaptor, they will show lower because your adding volume with no spark plug in the cylinder and the quailty of the guage has the biggest differance. I wouldnt worry as much about the actual number vs if they all are the same or not. A compression test is good to see if the engines in good shape(blown up or smeared rings) but it does not tell you the amount of leak down the rings let by if they are worn. A worn engine can build pressure rapidly but wont hold on to it very long.
Yup a L/D test tells a better story, when i brought the X home that's one
of the first things i did, showed only 3% loss @ 100psi on the worse hole,
not bad for 3,000 miles...
but she's still getting rings when it hit's 4,000 no matter what the L/D
shows then..
shows then..
JeepTherapy
daman said:but she's still getting rings when it hit's 4,000 no matter what the L/D shows then..
You guys have me convinced. Now that I know how easy it is to rering. Mine will probably be every other season now that I have the knowledge that I learned here.
Good for you for wanting to do things right.JeepTherapy said:You guys have me convinced. Now that I know how easy it is to rering. Mine will probably be every other season now that I have the knowledge that I learned here.
shavedheadedyamaha
ok i'm back from the shop and i got all three where the same and they where at 130-132.... so it sounds like im in ok shape right?.?.?.?.?.?.?
saskattakman
well you guys here have me convinced to rebuild my srx the rings and pistons were never touched since new now over 13,000kms so i think im gonna pull her apart and do pistons and rings after hearing all this
That looks alot better...shavedheadedyamaha said:ok i'm back from the shop and i got all three where the same and they where at 130-132.... so it sounds like im in ok shape right?.?.?.?.?.?.?
Yup it's time, you'll see that she'll run stronger then ever then.chevyracer68 said:well you guys here have me convinced to rebuild my srx the rings and pistons were never touched since new now over 13,000kms so i think im gonna pull her apart and do pistons and rings after hearing all this
