saskattakman
i am replacing the w-arm on my 98 msrx.....do i have to pull the whole skid or is it easy to do it in the machine???? i can raise the back of the sled 5 feet or so off the ground.....anybody done this??
terret725
pull the skid. not worth the hassle of attempting it. could possibly be done but IMO it would be alot more fustrating then the time savings are worth.
Yep pull the skid, your going to find wore out bush's too so do all it
at once..
at once..
Do it,unless the rest of the skid is in bad shape.
Yup that is the way I did it on my SXR a few weeks back,not that it needed replacing.I took the shock out to change the bushings,so decided to keep going and remove the arm to.That way I inspected it closely and did not find any cracks on the warm with nearly 10,000 km's on it.Changed bushings on the lower mount brackets that the arm attaches to.My uppers were good.I also put in grease fittings on the mounting brackets to get grease to them bushings.Changed my shock bushings with needle bearing bushings.Did notice the shaft going thru the upper part of the w-arm had a little uneven wear so replaced it with a spare one I had from another skid.
saskattakman
are the shafts usally worn.....just debating whether to order one since i jsut placed an order with port yamaha and it would be no problem for them to throw it in....
alot of times yes...chevyracer68 said:are the shafts usally worn.....just debating whether to order one since i jsut placed an order with port yamaha and it would be no problem for them to throw it in....
daman,you got a whole load of sleds there,why don't you donate one shaft from one of them and help out.LOL..I;ll paint your bathroom for you!!!
BETHEVIPER
Life Member
take the skid out. read the post below on skid repair. there are alot of things wrong in there.
Then i'd need a new one...all mine are new.bluemonster1 said:daman,you got a whole load of sleds there,why don't you donate one shaft from one of them and help out.LOL..I;ll paint your bathroom for you!!!
JERSEYJOE
w arm
Before you put it back in take the new W arm and have it reinforced or it is a time bomb and will break again. Someone on this forum did mine and it's now bullet proof.
saskattakman
ya you guys arent kidding about finding stuff wrong in there.....removed the skid tonight and found front shock bushings pounded out after 500 kms of new bushings....found lower shock mount bent into a banana....no bushings at all left in top w-arm shaft worn lots hadly any bushing left in lower w-arm mount....front tips of rails bent in about 2 inches each bent right at lower shock mount can't figure out why this would happen....2 cracks on both rails where the lower shock mount bolts go the crack if from the top of the rail to the bolt hole. can i get this welded???...found all the transfer rod bushings worn....ordered bearings for the front shock...new bushings to replace the rest of the worn out ones and follow bethevipers mods to beef up the w-arm and install grease zerks in the rest...
Blkhwkbob
I'd just look in the classifieds for a whole new skid.
saskattakman
well most of the bushings have been replaced...i have a new w arm and shaft and bushings now...so gonna take the skid to a machine shop and see what they can do...
Damn you ride hard. lol
saskattakman
are the rails weldable or is this just a problem waiting to happen if i get them welded....
I would find used, welding never seems to hold for long...
saskattakman
well the cracks arent too bad gonna get those welded the rail tips straightend and im gonna do the bethviper mod to add another bracket on the other side of the crack...figure steel with 3 bolts across the crack will hold better then 2 on the crack....get a new shock mount and see how long it goes for....thanks for all your input and help guys this site is awesome
http://www.totallyamaha.net/forums/attachment.php?attachmentid=20902&stc=1&thumb=1
