Pioneer long travel shocks
davessrx
port washington WI
I just put on Pioneer rear shocks on my stock SRX skid. The shocks are a little longer but seem to fit well. My question is this.....is there anything else I need to do??? Or just plug and play??? Everything looks good I had to adjust the front straps a little looser but that was it, anything to do on the rear shock or transfer rods??? The shocks were each about 1/2-1" longer than stock when out of the skid. Thanks Dave
I am doing this tomorrow. You need to put 2 spacers (10mm) one on each control rod. Take the bolt out on the bottom of the control rod and put in the 10mm spacer. You can get them from Yamaha. The part # is in the tech section.
SPACER THICKNESS (mm)
PART NUMBER
2.5
90202-16229-00
5.0
90202-16230-00
7.5
90202-16231-00
10.0
90202-16232-00
15.0
90202-16233-00
I do have adjustable transfer rods is that what you mean???? I know with stock transfer rods they make different spacers for different travel and such. I couldn't find it in the tech section, but I'm also a little impatient.
