et 300 oil pump setting
jminor1
Canada.
anyone know the stretch of the cable at wot? I have a 300 enticer in my shop I am working on and want to set the carb for him
Not sure what you mean by "stretch of the cable at wot" but the stock adjustment is as follows . . .
  1. Adjust idle mixture and speed.
  2. Adjust throttle cable freeplay.
  3. With throttle at idle position pull oil cable housing from carb end.
  4. Use adjusting nut to adjust exposed cable to 25mm (.098").
  5. Tighten locknut against adjusting nut.
This effectively adjusts the amount throttle travel before full oil delivery rate.
YAMMIEGOD3:16 said:
YA RIGHT !!!!!! PROBLEY PUTTING NOS ON IT FOR THE GUY. (who you kidding ). 3:16 (yammie tony)
should'nt you be worrying less about what I am doing and more about what you are going to do to get your srx and your vmax4 to keep up with my srx stocker next year????
GOOD, GLAD YOU WILL HAVE A SRX STOCKER NEXT YEAR. YOU WANT TO RUN MY 95 800 WITH A STOCK SRX ? LOL. ok!!!!!! 3:16 (yammie tony)
