Power valve ?
nysrx
New York
I have a 99 SRX chassis and am mounting a 98 SRX motor. I noticed the cable on the power valves off a 98 are way shorter than 99 and up. Where does the servo motor mount. Just looking at it it doesn't look like the cables are long enough to reach where the 99 had the servo mounted. Any under hood pic's would be appreciated. Thanks in advance.
yup mulder is right. You may just want to get the longer cables from the 99-up and mount the servo in the new location. It makes it a bit quicker and easier to get things apart and to get at the carbs. Your call though, cables aren't exactly cheap.
