ExpertXViper
What Im looking to do is gain some HP(mainly), better cooling EVEN though its not needed with just a single pipe, AND get the looks of the SRX heads. Can any year SRX head be modded and recut to run on prem. gas safely and gain some(3+HP)???? Or if I wanna do a mod like this am I stuck with using Peak head and domes???? Don if ya could fill me in with any of your ideas for something like this, Id really appriecaite it. Thanks
Brett
Brett
mrviper700
VIP Lifetime Member
Any year srx heads can be used, but you will still need a old mega power water rail to make it all fit. You can then make the compression ratio all the same and use a bigger main jet in the pto cylinder. There is a mod that can be done to a single pipe viper worth 10hp, this even shows up on a track dyno as increased power. pm me.
ExpertXViper
Pmed ya!!!!Don
ExpertXViper
Don PMed ya again with more questions......Thanks
