wls
I bought a new rear suspension shock for the sled, it compresses really hard, any trick to get it compressed enough to bolt up in the mounting brackets, with out having 4 hands? thanks
YAMMIEGOD3:16
GET SOMEBODY TO HELP YA. THATS GOOD THAT SHOCK COMPRESS HARD. 3:16 (yammie tony)
BuckSwashler
what i did was go to an auto parts store and get a small tie down rachet looped it around the shock and the tightened it down to compress the shock, worked like a charm, then i just cut it.
wls
I have a spring compressor, and can get it compressed that way, might take a plastic zip tie and try to hold it there, then get it in the brackets, and cut it loose. Hopefully it will work.BuckSwashler said:what i did was go to an auto parts store and get a small tie down rachet looped it around the shock and the tightened it down to compress the shock, worked like a charm, then i just cut it.
BuckSwashler
as long as the zip tie holds, prolly work!
wls
got it in, used a heavy duty zip tie.
BuckSwashler
sweet, now set me up with a clutch!
