vintage srx
My sled is ready to go replaced cracked slider rail front axle bearing cleaned power valves cleaned carbs , clutches and polished hood.
TopGunnSrx
Im good to go now! New top end, adjusted powervalves, changed the chaincase oil, new slides, greased her all up Ready to rock!
moss
Getting there, but need some parts to come in. Should get everything next week I imagine. Got some exhaust gaskets and bolts comin in, and new track. once that's in I can finish her up, and be ready.
Too bad we are getting like 20cm's tonight and tomorrow, and my sled is jacked up and skid out, waiting for a new track
My sleds are always ready, they were ready last spring.....
Roost 'Er
haha suspension is out, edge skid is half torn apart, just realised track is worst shape then i thought so gotta order new track and new studs, then gotta install both track, studs and the edge skid and once thats ready i gotta fix the wiring under my motor thats rubbing... needless to say i need a month.....
Skidooslayer687
lol motor out, hood and seat off, but as soon as thats back together im good, got to go get a new powervalve as i had a pull through last season, but other then that little pricey item lol im good
saskattakman
lets see who has the most work to do before winter lol.....got my 98 msrx carbs clean, new reeds, clutches cleaned, chain oil changed......rear skid out both rails cracked,w-arm cracked,bottom shock mount cracked, top end coming apart tonight for port job and new pistons and rings....waitin on parts and trailer repairs
Mine are all ready to,got some light snow today again,enough to run around the yard,I try on the weekend.More snow coming next week and temps are dropping.Soon will be able to take them out and play abit.But need a real good snowfall go run the the ditches.
kingtigg
WOOT!....just ran one of mine around the yard tonight...NOW I REALLY cant wait!
My 98-SRX is sitting up on a lift waiting for bearings before reinstalling new 136 x 1.25 track and extensions this year!...they should be in for the weekend....praying for snow now!
Lol!!!!!!!
I just gota ask about that chair on the back of a srx....WTF!!!!!!!
well mind the motor top end is all aparts loll... probably be all back together this weekend lolll... aways needs to search for new hp :-))
kingtigg
it makes for a really nice backrest on the long rides.......:-)
...JK....
this pic was actually taken right after several drag races between a bunch of us.
I'm giving one of our faithful spectators a ride back to the cabin we were staying at.
...good fun!
(BTW....the SRX faired quite well against the competition....>:-)
...JK....
...good fun!
lol i see.....was going to ask you last year, just had to this year, good to hear she running strong.
highboy77
Just had mine my REV out around the yard with about 2 inches on the ground, the SRX 700 has the power valves all cleaned I just have to play with some clutching and a few other odds and ends then I'll be able to go fast!!! I have to play now cause I'm sure our snow will be gone tommorrow.
Roost 'Er
chevyracer68 said:lets see who has the most work to do before winter lol.....got my 98 msrx carbs clean, new reeds, clutches cleaned, chain oil changed......rear skid out both rails cracked,w-arm cracked,bottom shock mount cracked, top end coming apart tonight for port job and new pistons and rings....waitin on parts and trailer repairs
haha top this...
-Edge skid completely disassembled, right now polishing rails and painting all arms may get rails powdercoated
-Reassemble the Edge
-Remove track
-Get new track
-Stud new track
-Install new track
-Make new mouting bolts for edge
-mount edge and new track
-fix wiring under motor
-remove and clean valves
-replace the one valve
Already completed:
-Suspension removed
-Old skis removed
-C&A's with 8" bides installed
02 Viper
That's why you have to have 2 vipers , one to work on and one to play on . Now I believe it's time to go PLAY ............. yeh snow in Barrie .......
we'er(thumb) getting "3 by tonight, wetter then hell tho.....
moss
We already have about 3" suppose to get more throughout the day and evening.
good bit of snow on the ground and my sled is jacked up, with the skid out, clutches out, exhaust off..lol
Things I still need to do:
- waiting for parts, exhaust gaskets, new clutch springs, new track
- need to order new Shock Bushings for the skid, and new Speedo Cable
- need to put the old spring onto new Shock
- install shock.
- replace track
- install skid
- put clutches back together, and install
well once the parts come in I should finish all this up in a weekend or so, but been waiting 2 weeks for parts so far, hope it comes in next week.
- install shock.
- replace track
- install skid
Finished the Viper shock swap, PP's small wheel kit and wheel spacer kit, cleaned power valves and all the regular maintainance is all done!! Can't wait to try out the new long travel!! Now all we need is some snow damn it!!
vintage srx
Working on a 98 srx needs power valve seals,cleaned clutchs needs drive axle bearing and idler bearings .Also going to clean carbs,found secondary set at 110 i think it should be 60 or 70 degre.IT has stock clutching.
