Hey Guys I Want To Switch Out Some Shocks On My 02 Viper And Just Wondering If I Can Sneak The Rear Skid Out With Out Taking The Whole Track Out I Havent Done Any Work On This Suspension. I Have Had Some Success Doing It On Other Machines. Whats The Thoughts Thanks
Go to the Tech section & you'll see a write up on skid removal...It's easy I take mine out every season to go over things...
Blkhwkbob
While it's out, do your slides, grease everything, check your w-arm and all the bushings.
rancidjo
Blkhwkbob said:While it's out, do your slides, grease everything, check your w-arm and all the bushings.
And if any of your bushings are worn, pull out the shafts to check for shaft wear
