sledcrazy
Has anyone here eliminated their oil injection and gone to mixed? If so...how did that work out?? Thanks!!
sledcrazy
Its a 700!!
Its a 700.. Has anyone here done this??????
srxdude1
I have several srxs and mm700 motors done you have to modify the case to get oil to the drive bearing where the oil pump and water pump is.look at the inside of the top half of the case make the center cyl like the other two. block off the hole where the pump went use 1/8th thick steel. mix 50 to 1.check your plugs for the proper jetting. works on all my sleds 98 srx780.2001mm944.97mm700 email me if you need anything else srxdude1@hotmail.com
