x2ryder
I am trying to put in new blue kimpex wheels I bopught from Yamaha. But it seems that the spacers that are supposed to fit into the wheels dont? Am I missing somethihg? They seem too big.
What diameter wheels did you buy and what location on the skid are you trying to use them? G.B.
You have to buy a mounting kit for those.I'm sure your talking about the 4 front outside wheels.I put them on my sxr. The mount kit comes with different bolts and spacers.They are kind of a pain,but really look awesome.
Are you talking about the plastic bushings that need to g on the wheels?
I have brand new bushings, enough bushings to mount 2 wheels.
Try using your old bushings too
x2ryder
I just turned down my old oem spacers to work. Next question though. Do you have to press of the 2 wheels that are right in front of the rear axl? Are they the same inner diameter bearing size as the 4 I just put up front?
I just did this last week.
The axle that is between the rails just in front of the rear axle, are press on bearings. They do not require bushings. Just revove the snap rings that holds the wheel on the shaft (not the snap ring on the wheel) and press the old wheels off and press the new wheels on. It is so simple its stupid.
Tom
Tom
