MrAttak
ok i put on a 1 1/4 ripsaw last year put it seems to be rubbing can anyone tell me what i can do to fix the rubbing problem the track is rubbing my rad pertectors never notice it before until i wanted to stud the track how can i fix this i am putting 144 studs in 1.325 can anyone help on what i can do the track is new last year.
thx jerome
			thx jerome
I'm not a stud kind of guy but I'm thinking your going to either have to let it wear into the protectors, notch it to clear the protectors, switch to 8 tooth drivers, or switch to a shorter lug track.
			04 viper s has no protectors at all...so just remove them...unless your gonna stud, then just notch them...do a search, you'll see its been talked about...alot
			MrAttak
i don't want to remove them the protectors and yes i plan to stud the track just wondering how i can get around the rubbing part if i have to goto a 8 tooth driver so be it i will i think that is my only opion i think?
			YamaChris
or as Ryan B said notch track between windows slightly or let it wear in on its own.
I myself did the notch thing,not a big job to do either,just trim a little with sharp utility knife.
