Where Is My C. D. I BOX LOCATED ?? Also Key Help
Diceman
New Hamburg, Ontario
Hi Guys, misplaced my keys for my 1998 vmax 700 xtc....was told if I copy down the numbers that are on the ignition I could get a key cut from it....well went to the dealer today with the number but all I can get is a blank key...was told to unplug ignition wire from the cdi box and take it in to a lock smith and they could proably cut one for me....is the cdi box easy to get to to unplug the ignition wire?? Do not want to start taking things apart if I do not have to...Can not seem to see the box or even where the wire harness goes to...Is there an easier way or diffrent way to get a key done???? Thanks guys....Diceman
daman said:
What about just finding and used ignition with key, and swap 'em out?
Hey Man...yes I thought of that but was told that for about $10.00 I can get a key cut...either way I will have to take it out....so my man, where is that box...lol...???
find an ignition switch
post a picture of it in the WTB classisifieds section. The plug in has to be correct for your wiring harness.
I know this cuase 98 and 02 SRX are completely different wire harness
Your CDI is located on the left side where you sit right behind that black vent off to the left side of the gas tank.
Your CDI is located on the steering hoop behind the plastic where your left knee would be sitting on the sled.
on a '98 xtc....
your cdi(black box,thin) disc is on the right side(attached to the air box) as your sitting on the sled,there should be 3 pugs going ito it.
Thanks boys but one guy says is it on the left and one guy says on the right,??? Do you have to take anything off to get at it?? Thanks
you can't miss it disc look on the side(one of them)for a black box thin
with 2 or three plugs going into it.
i'll post a pic if needed..
should be right side air box..as your sitting on the sled
You were right Damon..it was on the right side..actually did not even have to unplug ignition harness from the cdi box...ignition has a wire harness that is about 8 inches long which then plugs into the main wire harness that goes to the cdi box... just pulled back vent plastic , followed the wire from the ignition until I saw the plug, unplugged it and know all is good...will try first to get a key cut first since I am told I can get it done for about $10.00....if that does not work then I will try to buy a uesd one..Thanks again boys..Diceman
DUH!!!
I forgot on the vmax models its mounted elsewhere not like the SRX's and vipers.
Glad you dound it though
Well took key ignition to a yamaha dealer but even with the ignition codes they could only order me a blank key so I went to a locksmith and 7 minutes later problem solved....Cost $15.00 for new keys....Thanks again guys
daman said:
good dice..how did the L/S help, what he do, open your lock up?
Nope he just punched my numbers of the ignition into his computer..says that all ignitions for the most part are the same..was in and out in less than 10 minutes.....hey Daman read my post on Oil in the gas ..Thanks Diceman
Hmmmm....good to know, thanks for the info.
