apexdreamer
I have a perfect rear cooler from 01 sxr 700 is it enough for the viper or should I hold out for the srx cooler? thanks
apexdreamer
another question about the cooler
the sxr cooler empty and flushed and dry seems to have something inside of it is there deflectors inside or something maybe some fins or something to help diffuse heat any one ever seen the insid e of one of these? thanks
Yes it will help, your vipe should have came with only the crossover tube(unless it's a moutain)so anything up from that yes will help, but....you'll
need one from a vipe because there(vip vs sxr)a little different,the angle
of the hose tubes, and the hose size's is different too(i think).
see the differance;
viper,
SXR,Vmax
see the differance;
viper,
SXR,Vmax
