Tracks Srx
D-HK45
wi
Hi Dan Here I Just Bought My First Yahama Srx 1998 For $1000 The Guy Was Going Threw The Big (d) So It Had To Go. My Q Is I Would Like To Know Whats A Good Track To Go With And How High Of A Paddle I Can Go And Studs. 2 Q Is I Want To Go With More Travel In The Rear What Sup Can I Use I See You Can Use A Rx-1 What Will I Need For It To Work. Our Should I Just Leave It Stock. And What Is The Standerd Lenigh Of The Srx Track. Thanks For Your Time
Ill try here, standard track is a 121"x15", 2.52 pitch
Q 1- with studs stick with a 1" track, camoplast predator and hacksaw are very common choices if you want a taller paddle go with 8 tooth drivers
Q 2- You can put viper long travelled shocks in for the quickest fix, do a search and youll find tons of swap info
any other questions dont be afraid to ask :)
