Changing brakes on a 92 Phazer
zooman
Cameron Ontario
Hey guys I want to put some new brake pads on my 92 Phazer. Are there any good tips out there? I have the caliper off and how do you get the brake pad off the caliper. I am thinking it might be siezed up. If I pull the brakes on the pad doesn't move. I am thinking I should take the caliper apart. Also how do youi get the brake pad off of the other side of the disk?
Thanks for the tips guys,
Matt
The disk and jackshaft have a keyway and slot. If the disk is free you should(?) be able to side/pry it away from the chaincase enough to slide the brake pad out ?
